tranny problem
Old Nov 6, 2007 | 09:57 PM
wilb86's Avatar
wilb86 is an unknown quantity at this point
Default tranny problem
I had a leaky water pump and thermostat in my 95 4wd blazer. While i was changing them i decided i might as well change the tranny fluid and filter at the same time. It all went smoothly until i got the car running and noticedI had aSES light. The car runs great and all coolant problems are gone. The problem now is that the tranny wont shift into first even if i try to drop it manualy with the shifter. It will not downshift into any gear if i floor it and wont go into first at all. I havent checked the tranny fluid level if anything its a little high but i dont see that causing this. What do you guys think?
Old Nov 6, 2007 | 11:57 PM
blazinloud's Avatar
Default RE: tranny problem
welcome to the site!
not that I can solve your problem but it must be something fairly obvious. I'm sure someone here can help.
ski.dive
Feb 7, 2014 05:18 AM
bouser
Dec 10, 2009 11:46 PM
lovetheblazer
Mar 13, 2006 01:00 PM
sting_da_man
Mar 13, 2006 12:48 PM
nine5blazer
Oct 18, 2005 05:19 AM
