tranny problem?
Old Aug 3, 2012 | 03:56 PM
50lb_cat's Avatar
Default tranny problem?
I had my tranny replaced on my 99 jimmy, 4.3, push button with auto 4x4 about 3 months ago. Now when I get to about 30 mph, I hear a slight whine type of noise. I'm thinking its a tranny issue because if I cost down a big hill going 30, there is no noise. Wouldn't a hub still make a noise regardless of if there is torque or not?
Old Aug 9, 2012 | 01:18 PM
50lb_cat's Avatar
Bump, the noise is more of a humm
Old Aug 9, 2012 | 04:05 PM
El_Beautor's Avatar
I've heard that plaid is a good tranny repellant for your whiny tranny problem. Wait... You're talking about your truck. Gotcha. Are you positive that the sound is from your transmission and not something else like U-joints? It could also be the front differential not totally disengaging or engaging if you've shifted. That turned out to be my problem: My front diff wouldn't totally disengage for a while and had a growling sound until I could get it to kick out.
Good luck. External sounds are really hard to track down.
Old Aug 10, 2012 | 12:45 AM
50lb_cat's Avatar
Lol guess I should have been a bit more precise in the thread title. I thought that as well about the front engaging but I tried it in 4x4 and its still making the humm. I'm about to throw on new u joints to see if that helps. What did you end up doing on yours? Thanks for the reply!
Old Aug 10, 2012 | 03:02 PM
El_Beautor's Avatar
My problems ended up being either the driver's side CV (most likely as it was quite sloppy when I got it out) or internal to the front diff. I replaced them both at the same time as part of upgrading from 3.42 gears to 3.73, so I can't say absolutely difinitively that it was the CV.
ski.dive
Feb 7, 2014 05:18 AM
bouser
Dec 10, 2009 11:46 PM
lovetheblazer
Mar 13, 2006 01:00 PM
sting_da_man
Mar 13, 2006 12:48 PM
nine5blazer
Oct 18, 2005 05:19 AM
