Tranny Problem???
Old Jan 13, 2015 | 02:21 PM
newguy's Avatar
about every 6 months I open my tcase fill hole, drain out a quart or so while keeping an eye on the trans level. For now, easier of the 2 options
Old Jan 13, 2015 | 05:18 PM
Red Sled's Avatar
Red Sled is on a distinguished road
Now were talking!!! Great Idea
Old Jan 20, 2015 | 01:36 PM
princered72's Avatar
princered72 is on a distinguished road
Originally Posted by Possum 6991
If the seal between your transmission & transfer case goes bad, it will let transmission fluid go into your transfer case and will overfill your transfer case. If the vacuum switch on top of your transfer case goes bad it will allow the transmission fluid to be sucked into your vacuum lines which operate the 4WD actuator & HVAC controls on your dash. If this happens you should replace all of the vacuum lines. This does not seem to that rare of an issue. I just replaced all of the vacuum lines in the engine compartment, vacuum switch & seal because of this problem. Hopefully I won't have to replace the vacuum line inside the dash.
I myself will also be double checking the fluid level on the stick just to make sure, but how do you know it was the vacuum switch. I check the transfer case and nothing came out. Can you smell it? Does some of the HVAC not work?
Old Jan 20, 2015 | 04:53 PM
newguy's Avatar
Disconnect vacuum line that go to your hvac(underhood) if there`s tranny fluid in them, question answered
Old Mar 18, 2015 | 06:40 PM
Christopher B's Avatar
Christopher B is on a distinguished road
good information guys,..all is very helpful...thank you!
ski.dive
Feb 7, 2014 05:18 AM
bouser
Dec 10, 2009 11:46 PM
lovetheblazer
Mar 13, 2006 01:00 PM
sting_da_man
Mar 13, 2006 12:48 PM
nine5blazer
Oct 18, 2005 05:19 AM
