tranny problems help !
Old Nov 23, 2010 | 07:03 PM
Crispy23's Avatar
Crispy23 is on a distinguished road
Default tranny problems help !
my tranny shifts hard into second and slips out of gear every now and then. what is that. also latley when ill start it and dont give it time to warm up it will sputter when i drive it and then after a bit it with get full power and be fine . please help thank you
Old Nov 23, 2010 | 07:50 PM
Vehicle Information??
Old Dec 22, 2010 | 10:02 AM
Crispy23's Avatar
helppppp!!!!!
1997 blazer lt 4 door
Last edited by swartlkk; Dec 22, 2010 at 10:06 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Dec 22, 2010 | 10:06 AM
Now that you have provided that MUCH needed bit of info, how about you go further to list what gear you think it is slipping in, the conditions (throttle position, engine speed, vehicle speed, etc) under which it is slipping, and any other pertinent details concerning the issue(s) you are requesting help with.
No one here can read your mind!
Also, you could try the search feature. The harsh 1-2 shift has been discussed before.
Another avenue for self-help is reading through the tech article index under which you would find this thread:
4L60E Information & Common Problems - Compilation
AtlantaRider
Dec 28, 2010 02:41 PM
snaumo
Aug 31, 2009 01:03 PM
upblazer95
Apr 4, 2009 08:27 PM
marketmagoo
Oct 9, 2008 02:40 PM
Zack98Blazin
Aug 30, 2006 05:45 PM
