General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Please Help-98 Blazer 4.3 -wierd tranny problems?
Old Aug 14, 2006 | 05:21 PM
Zack98Blazin's Avatar
Zack98Blazin is an unknown quantity at this point
Default Please Help-98 Blazer 4.3 -wierd tranny problems?
Hello to all, and thanks for helping!!!!!!
I am new at this fourm and have been searching but couldn't find anything about my problem with
the Blazer First off it is a 1998 Blazer Ls 4door 4X with a 4.3 liter and auto trans.
Any way to get to the point the vechile runs great when you drive it like a grandma,
but when you even try to accelerate to get on the interstate , or actully any time you
acclerate quick the rpms go to 3500rpm and it will not shift untill you let off the gas.
I thought it was the transmission sliping till the rpms won't go over 4000rpm when this
happens.
Oh and After two weeks of this the C.E.L come on.
anything sound familar to anyone?
thanks allot
Zack
Old Aug 14, 2006 | 05:23 PM
Default RE: Please Help-98 Blazer 4.3 -wierd tranny problems?
If the CEL is on, you really need to have the codes checked. It may help point you in the proper direction.
Do you run a K&N (or aftermarket oiled air filter)?
Old Aug 14, 2006 | 09:52 PM
mortalum620's Avatar
mortalum620 is an unknown quantity at this point
I have had the same problem. Still no idea whats goin on. Sorry i cant help ya, but at least i can feel your pain
Old Aug 14, 2006 | 10:08 PM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
Is the correct transmission fluid in it to the correct amount? It might sound dumb, but some problems are caused by the simplist of things, like low fluid.
Old Aug 16, 2006 | 08:36 PM
mistasmiff's Avatar
mistasmiff is an unknown quantity at this point
Ive got a 99 4.3 same setup. I had the same exact problem. The code it pulled (dont remember the number) ended up being "transmision short circuit B". I dont know much about trannies but its an electrical circuit component in the transmision. It should deffinately throw a code if this is the issue.
Had it replaced and everything was back to normal. Wasn't too cheap to have a shop do it. I had a lot of suspension work done at that time so i cant remember the exact cost but somewhere between 2-400.00.
Old Aug 17, 2006 | 02:55 AM
Hanr3's Avatar
IT could also be a failing torque converter.
Did you check the tranny fluid level?
What does the tranny fluid smell like, and what color is it?
Old Aug 30, 2006 | 12:12 AM
cplca's Avatar
cplca is an unknown quantity at this point
Could be a bad trans sensor or worned-out wire at the ECM I don't think it would be your torqk converter but could also be your EGR valve although a bad EGR would have a jerking feel. Best is to pull codes first if any and go from there.
It wouldn't be a bad idea to check the wires at the ECM, Traces of rust or burn marks on wires
would be an indication that something is or is about to go wrong in this area. I had similar problems with my Impala SS a few years ago, my trans would only shift a very hight rpm because of one faulty wires.
Please let us know what you find.
Old Aug 30, 2006 | 05:45 PM
Mariongo's Avatar
Mariongo is an unknown quantity at this point
I had the same problem a while ago and it turn out to be a "transmission (TCI) turbine sensor solenoid" and I had it change along with the fluids and filters
And that's it. It ran me 150 bucks.
You need to have your tranny computer diagnose...
96jimmyslt4x4
Aug 28, 2011 10:44 AM
snaumo
Aug 31, 2009 01:03 PM
bills96
Jun 16, 2009 10:04 PM
CAPranger4300
Sep 29, 2007 09:25 PM
aris_unlimited
Sep 29, 2006 09:51 PM
