Tranny Questions????
Old Feb 24, 2009 | 04:31 PM
Chevy Dogg71's Avatar
Chevy Dogg71 is an unknown quantity at this point
Default Tranny Questions????
I recently picked up a 98 LS 4x4. The tranny seems to not know when to shift into overdrive. It constantly shifts up and down. Also, when it is doing this, every once in a while it shutters like crazy. It feels like you are hitting rumble strips when it does it. The fluid looks good and isn't low. All the other gears shift fine. Any body got some ideas????[sm=dontgetit.gif]
Old Feb 24, 2009 | 07:35 PM
Default RE: Tranny Questions????
Sounds like the TCC solenoid (torque converter clutch) has worn out the bore which the valve rides in. This will typically trigger a transmission code before getting to the point of a noticeable problem, however, if the torque converter clutch itself has worn down, it could cause the shudder.
Old Feb 24, 2009 | 11:24 PM
Does that mean a rebuild or is this part serviceable?
ski.dive
Feb 7, 2014 05:18 AM
newguy
Aug 31, 2012 05:38 AM
j5ep
Jan 14, 2010 10:45 AM
95POSmoneypit
Sep 19, 2009 04:19 AM
vankuen
Sep 22, 2007 05:26 PM
