Tranny Replacement
Old Jun 8, 2009 | 08:37 PM
rlbellarosa's Avatar
rlbellarosa is on a distinguished road
Default Tranny Replacement
A recent change of tranny fluid has lead to a thunking occassionally when shifting. We've decided the best thing to do is replace the tranny. So the question is:
Would the tranny from a 92 or 93 blazer fit (easily) into a 97 blazer?
Old Jun 8, 2009 | 08:48 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
i dont think a 92 would work beacuse i do not beleive the 4L60E was availible in blazers, but if the 93 has the 4L60E and has the same drivetrain(both vehicles being 2wd or 4wd) it should be fairly straight forward. if you stick around a bit someone with a lil more knowledge will chime in and give you a definite answer.
Old Jun 8, 2009 | 11:02 PM
You do not want to go backwards with the 4L60E. Newer only! Modifications have been made to the transmission over the years, some of which are required to safely operate in your truck.
Old Jun 9, 2009 | 10:24 AM
Colby 04's Avatar
Colby 04 is on a distinguished road
I think it might benefit you to drop the pan and re-check everything that could have been dinked with during the fluid change.
Old Jun 9, 2009 | 10:55 AM
We've known the tranny has been going for awhile, there were codes in for things slipping, it was just a matter of time. I'll be moving soon and will no longer have a free mechanic (my dad) around to fix things. The only real option in this specific situation is replacement and my dad knew a friend with a 92 or 93 for cheap.
Old Jun 10, 2009 | 10:22 AM
Colby 04's Avatar
Is it actually slipping?? The 'code' for slipping could just indicate that your torque converter isn't locking properly at highway speeds. That will generate a trouble code and increase the line pressure that gives you a very firm and noticebly different 1st-2nd shift. I've heard that this could be caused just by the valve body within the transmission. I have the same problem and did a little searching on it. Your problem sounds more and more like what I just described...
ski.dive
Feb 7, 2014 05:18 AM
IrishDrums85
Jun 7, 2012 08:51 AM
Thrakhath
Nov 1, 2011 08:22 PM
dj00140
Mar 14, 2011 09:42 PM
hyperchargedvol
Oct 15, 2010 04:05 AM
