Tranny Slip or What?
Old Nov 20, 2011 | 07:03 PM
Chevra's Avatar
Chevra is on a distinguished road
Default Tranny Slip or What?
I have a 95 blazer and just recently it has been giving this problem. When I go to floor it to pass someone it just revs out and doesnt pull at all. Is this my tranny slipping or could it be something such as my torque converter. I have also noticed that the blazer revs at about 2400 rpm when going 105 km/h. This seems a bit high to me. It seems to mostly do the slipping on the highway, dont really notice anything strange in the city. The tranny is also pretty new, maybe 5000 kms on it now. Please help.
Old Nov 21, 2011 | 09:52 PM
heeb2424's Avatar
heeb2424 is on a distinguished road
So the slipping happens most when its at higher speeds correct? If the slipping is happening at higher speeds then it is you TCC. Do you notice any other gears slipping or just high speeds?
Old Nov 22, 2011 | 09:36 AM
Chevra's Avatar
It seems to be just at high speeds. The transmission has always had slow dragging shifts but never seems like its slipping in the city. It also seems like after a long drive on the highway once I get back intot he city it shifts hard from 1st to 2nd. It jerks pretty good but that is only after long highway drives and not always either. It is hard to explain but yes the problem seems to be slipping or whatever it is while passing on the highway.
Old Nov 23, 2011 | 10:08 AM
heeb2424's Avatar
Yea if it's slipping in overdrive then that would be your TCC slipping but im not to sure about the hard shifting part after long drives. I'd have to look more into that one for ya.
Old Nov 23, 2011 | 11:49 PM
Chevra's Avatar
Well my fluid might have been down a bit. I finally got to check it out in the daylight for once. I added some now and it brought it up to the hot line. Before I added it didnt look burnt or anything so I will see if this improves it or not. Havent had it on the highway yet but around the city it seems a bit smoother. This weekend will be the test, im hoping that was my issue. Thanks!
Old Nov 28, 2011 | 10:10 AM
heeb2424's Avatar
Yea me too! Your very welcome
coolcat0285
Oct 29, 2012 10:18 AM
kingzero
Jul 25, 2009 08:46 AM
Jorgen
Nov 6, 2007 03:06 PM
psfitzgerald@shaw.ca
Jul 9, 2007 05:30 PM
hdlogistics
Apr 10, 2006 03:03 PM
