Tranny slipping Shop says it was tran cooler
Old Jan 21, 2009 | 04:55 AM
painter203's Avatar
painter203 is an unknown quantity at this point
Default Tranny slipping Shop says it was tran cooler
Recently had problems with transmission slipping out of drive when driving for hour or more. Took it to the tranny shop and they said the transmission cooler was clogged and caused 3-4 or 2-4(can't remember) band (or clutch) to go bad. Don't know squat about transmissions, does this sound right? They charged 1400 for rebuild, new transcooler and lines.
Old Jan 21, 2009 | 09:34 AM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default RE: Tranny slipping Shop says it was tran cooler
A Tranny that has overheated will burn up the clutch plates inside, so If your cooler went bad and your tranny wasnt cooled, this is possible. #1 Transmission Killer is Heat. once temp start spiking above 220 F Varnish will form and turn to carbon, then 240 F to 260 F Seals Harden and Plate Slip and above that youll burn the clutch packs up and oil turns black, carbon like. So I Would say it sounds right. Just my .2 cents
Old Jan 21, 2009 | 10:29 AM
Hanr3's Avatar
What blazin said.
Plus its the 2/4 band, it goes around the clutch pack.
Get kevlar (High energy) replacement clutch packs.
Old Jan 21, 2009 | 04:14 PM
AJBert's Avatar
Also install an aftermarket tranny cooler, though in your particular situation it wouldn't have helped if the factory cooler got clogged.
I do have to say first time I've ever heard of a tranny cooler clogging, though. I would guess you had some other problem inside the tranny causing the clogging of the cooler.
Old Jan 21, 2009 | 07:46 PM
ORIGINAL: AJBert
I Agree on this, the only thing that clogs up the fluid and filter are the metal filings from the gears, clutches on the transmission. So the fluid would have to go thru the filter and it would clog up thier first. Your Radiator Could have an internal crack possibly. Did you have that checked, you dont want tranny fluid mixing with Antifreeze or Vice Versa.
Dare87
Jan 12, 2011 07:44 PM
josephdstone
Sep 23, 2010 11:30 PM
cgower
Apr 27, 2010 08:33 AM
TriBlaKer
Mar 22, 2010 10:13 PM
Jetfixer
Jul 11, 2006 05:02 AM
