Trans fluid leak
Old Nov 10, 2007 | 02:33 PM
harleybob's Avatar
harleybob is an unknown quantity at this point
Default Trans fluid leak
I just took my recently purchased 95 Blazer for a ride. It has an automatic transmission and I just replaced the 4WD switch which was broken. It rides fine in 2WD but as soon as I switched it to 4WD, transmission fluid started pouring out of a rubber hose on the toward the top rear of the engine compartment (passenger side).It looks like a vacuum hose and last week my mechanic said it was just a vent hose. Could he be mistaken or should this hose be connected to something? I don't want to drive it until I understand if there's a problem. Thanks
Old Nov 10, 2007 | 07:25 PM
Default RE: Trans fluid leak
The first thing I would recommend is pulling the fluid fill plug on the transfer case. It is quite possible that the rear seal on the transmission has failed, filling the transfer case. If you get fluid out of the fill hole (upper plug), then you will need to replace the rear seal on the back of the transmission by pulling the transfercase.
razman
Dec 30, 2014 10:14 PM
Gkolo1
27
Oct 26, 2012 05:58 AM
AlpineFox19
Aug 18, 2011 09:22 PM
luthers97blazer
Nov 10, 2008 01:27 PM
pbrew
Apr 30, 2008 12:11 AM
