Trans fluid mystery
Trans fluid mystery
Hey all, I've got a problem that I hope you can help me with. Lately I've noticed a strange sound w/ the Blazer. I can only describe it as a high pitched but quiet whining sound that's completely in sync w/ the transmissions gear shifting. I've never heard this before, so I checked the tranny fluid, and it was almost empty! Only a small drop at the very tip of the dipstick. I went ahead and added some to the right level and didn't notice the sound again. That is, until the next day. Same thing with the noise and tranny fluid level. I see no fluid under the truck, and nothing looks out of the ordinary in the engine compartment. The truck is running great. So, anyone got any ideas here? Am I missing something, or not looking in the right place? Any input is appreciated. Thanks!
RE: Trans fluid mystery
Pop off the fill plug at the back of the transfer case. Typically, this is caused by a leaking rear seal on the transmission, between the transmission and the transfer case. If this is the cause, then the transfer case is probably full of transmission fluid. Bad part is it requires the removal of the transfer case to replace. Good part is that if you can do the work yourself (with the help of a friend - the t-case isn't exactly lite), the seal is cheap!
Thanks Kyle--Luckily a buddy of mine has some good experience with trnsmissions-and has a good sized shop at home. I'll print out your recommendation for him and let you know what happens. BTW--any idea about that whining sound w/ the transmission when it's changing gears? Thanks again!
Steve
Steve
The whining sound could be caused by metal to metal contact where a fluid layer would typically be. It is possible that it may go away once you get the fluid level stabilized. But then again... Noises of this type are very difficult to nail down to one thing especially when you are talking about the transmission...
Usually when an automatic transmission whines that is an indication that the front pump is on it's way out ...
Zed
Zed
and the failed seal will be in the front of the t-case. there is no rear seal in the tranny when its mounted to the t-case. the tranny rear seal is in the tailhousing, since its mounted to t t-case there is no tailhousing.
tcase weighs about 100 pounds empty.
hunter05
05-07-2013 03:29 PM
DaleA
01-13-2009 08:50 PM
ironclad
08-18-2008 04:05 PM
