trans pushes fluid out vent pipe
Old Jan 24, 2020 | 07:33 PM
Dobieowner's Avatar
Dobieowner is on a distinguished road
Default trans pushes fluid out vent pipe
New to the forum. Have A 1985 S10 Blazer 4X4 2.8L automatic. Keeps pumping trans fluid out vent pipe. Been in two different transmission shops. What can cause transmission to build pressure and blow fluid out vent pipe?
Old Jan 24, 2020 | 10:14 PM
AJBert's Avatar
A trans that is overheating.
Old Jan 25, 2020 | 01:10 PM
Transman304's Avatar
Welcome to the forum first off. Glad you found us lol! After you lose fluid are you having to add more fluid to transmission? If so what amount approximately? My guess is the fluid is entering the transfer case from a failed seal. I can’t really recall how the vent hoses for transmission and transfer case were routed together or separate for those years of the 700R4. May want to check level on T case but be prepared to make a mess if in fact it is overfilling.
Good luck
Brad
tim68
Oct 28, 2011 09:08 PM
builder125
Apr 17, 2011 09:20 PM
jimbo228
Aug 21, 2009 02:03 AM
luthers97blazer
Nov 10, 2008 01:27 PM
jbelllive
Jun 21, 2008 11:25 PM
