Trans wont shift out of 2nd
Old Oct 5, 2010 | 11:20 PM
mntmotor's Avatar
mntmotor is on a distinguished road
Default Trans wont shift out of 2nd
98 Blazer wont shift out of second. Any ideas of what it could be or what i can try?
Old Dec 28, 2010 | 11:17 AM
doobie98dailydriver's Avatar
doobie98dailydriver is on a distinguished road
recently I replaced my trans filter and must have it my 2-3 shift solenoid puting the pan back on. When I took it for a drive it would act like neutral when it should have shifted into 3rd. Replaced the solenoid and it worked fine. Until a week ago when it started doing it all of a sudden. I dropped the pan replaced again since under warranty but it did not fix it this time. If you find an answer let me know.
Old Dec 28, 2010 | 12:03 PM
The OP's problem very well could be a solenoid issue which is a simple change after dropping the pan.
Your problem doobie could be a result of a damaged wiring harness in the pan.
steelcityneal
34
Oct 6, 2017 06:10 PM
4thgenceli
Mar 25, 2011 06:06 AM
Juice01
Aug 27, 2010 12:10 PM
texas4x4blaze
Jul 16, 2010 08:51 PM
Ugly_Monkey
Apr 20, 2009 10:40 PM
