transfer case?
I have a 1984 S10 blazer 4x4 with a borg warner 5 speed transmission with a 2.8 v6. I am trying to find out what transfer case they used in it. I can't find any label other than a barcode 604881N and then some more numbers on the case C15510 either ND or NP next to it? I am trying to find the gasket that goes between the transfer case and transmission. Any help would be appreciated. Thanks
I am not 100% sure what t-case you have, it could bea 205, 207, 208, 231, or a 241. You can use a bead of silicone between the two, instead of a gasket, I have done it this way many a times, with no problems at all. HTH.
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
loscochinos520
May 28, 2005 11:32 PM
