Transfer case adapter
Old Jan 2, 2017 | 09:55 PM
ffbailey's Avatar
ffbailey is on a distinguished road
Default Transfer case adapter
Hi, i recently bought a 96 bravada awd. Well my problem is that i bought it with a blown trans. I have a spare already for it but im concerned its got something seriously wrong. The adapter between trans and transfer case is broke and im told that it was broke when the trans went out a couple years ago also but had been replaced. What in the world could be causing this to happen?
Old Jan 3, 2017 | 08:12 AM
Transman304's Avatar
See this a lot on Allison transmissions when a u joint is bad or a slip yoke is frozen. With the AWD t case you must use all four tires of the same diameter.
Old Jan 3, 2017 | 08:37 AM
ffbailey's Avatar
It does hava all 4 tire same size and all new ujoints but the rear slip yoke was sticking a very slight bit.
Old Jan 3, 2017 | 08:51 AM
That could very well be your problem. Also the viscous coupling in the t case may be seizing up.
Old Jan 3, 2017 | 01:59 PM
ffbailey's Avatar
How exactly would i check the viscus coupling. Ive never messed with a awd before.
Old Jan 3, 2017 | 07:45 PM
Do you have any binding in the front wheels when turning right or left?
Old Jan 3, 2017 | 08:35 PM
ffbailey's Avatar
I have no idea. I got it with a bad trans.
Old Jan 4, 2017 | 07:13 AM
No way to check it not running.
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
willyman82
Aug 21, 2012 09:11 PM
Devink5
Oct 5, 2011 11:10 PM
XBlazer01
Aug 3, 2006 04:05 AM
