Transfer case help
Old Jun 8, 2010 | 03:09 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Try this. I bought some stuff through it. Sometimes the stuff hasn't been updated but I found a whole front clip for my 84 Jimmy for $250.00 with a great A/C condenser. I'm just afraid that if you jeep driving it you aren't going to have anything to put back together.
http://www.car-part.com/
Old Jun 8, 2010 | 06:59 PM
spaceapex's Avatar
spaceapex is on a distinguished road
Default Update
So I wanted to make absolutely sure the noise was coming from the transfer case. I put the truck up so all four were off the ground started it and put it in drive... NO NOISE!! So there is only noise when all the wheels are on the ground.. The next thing I did was pull off my Front drive shaft.. The U joint is dry and dirty but no play.. Drove the truck around without the front shaft attached and NO NOISE... Feels like there is less resistance. I am just going to drive it like this for a while since I don't need 4x4 till winter.. So could this be a noise that happens only under load? It was clanging weather in 2hi or 4hi didnt matter. I might just be stuck with a 2wd blazer.
Old Jun 9, 2010 | 02:55 PM
How's your oil level in the t-xase and your front differential? Does your front cable to your front drive release all the way? You also might check your vacuum switch on top of the t-case. In other words the driveshaft might have been making the noise but being driven to rotate not being the driver. If everything checks out OK I'd grease the U-joints and stick it back in and see. Also could be your front output bearing in the t-case if the shaft was being driven by the front differential. Fix it man!
Old Jun 10, 2010 | 08:44 PM
spaceapex's Avatar
Fluids checked good. Wont the front drive shaft spin regardless if it is in 4x4 or not? It was making the noise when I went into 4x4 also.. same sound. Clang clang clang. I will figure it out hopefully before winter but at least I can drive it in rwd now and have time to do more research. A rwd blazer is better than a dead one. Thanks for all the help guys!
Old Aug 11, 2010 | 02:43 AM
spaceapex's Avatar
Default Got it!!
Well I pulled off the front drive-shaft and replaced the u joint even though it seemed ok.. NO MORE CLANGING NOISE!!! Thanks guys! only cost me 20 bucks!! I traded my 1988 bayliner for a 1982 yamaha maxim 650. My 1st bike!
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
Vermilion
Aug 31, 2008 08:35 AM
mdkuni
Apr 10, 2008 07:00 AM
95_4door
Mar 21, 2008 07:22 PM
