any one know if there is an electronic transfercase with a nuetral position and if so wat are the #s on it ive tried search w no luck i would like to swap out tcases so i can flat tow
Not one that would fit into your truck. You can force it to neutral by removing the encoder motor and placing the sector shaft between the 4HI and 4LO detents.
