transmission
Old Feb 17, 2012 | 04:32 PM
mkuljis's Avatar
mkuljis is on a distinguished road
Default transmission
I have a 95 chevy blazer and need to know if i can use the tranmission out of that and put it into my 97 chevy blazer
Old Feb 17, 2012 | 09:18 PM
chris015's Avatar
if its a 4l60e,im 95% sure it will....Not sure if the electrical computer part is any different.
Old Mar 21, 2012 | 07:52 PM
jhnmrty's Avatar
jhnmrty is on a distinguished road
Did it work? I got a 96 with a bad tranny and i can get one from a 95....
Old Mar 22, 2012 | 10:55 AM
RedSquirrel's Avatar
RedSquirrel is on a distinguished road
all automatic blazer transmissions from 95-00 are the same, i believe, thats what i have been told, as long as it out of a blazer with the same drive train as yours (as in 4-wd or 2-wd)
Old Mar 22, 2012 | 11:03 AM
That is not entirely correct. While they are all 4L60E's, they are not all the same. '95 had some changes that occurred part way through the year in the way that the TCC (torque converter clutch) actuated. If the pump cover (behind the torque converter) has the letters 'PWM' on it, then you could use it in a '96 thru early-'97 application. I still advise to go newer and not older though as other improvements have been made that are backwards compatible.
Sometime in '97 GM changed to a two piece bell housing to allow the transmission to mate up with the new LS series engines. If you are not afraid of a little fab work to create a new dust shield, then a late-'97+ 4L60E w/ a 2-piece housing will work. To make a dust shield, use your current dust shield as a template for the starter cutout location & the cutout around the pan. Then make ears for the bolts on the trans adapter that would have had bolts into the cast aluminum oil pan.
One other thing worth mentioning is that it was sometime in '97 that the bolt pattern at the back of the transmission changed from a 4-bolt pattern to a 6-bolt pattern. If you find a trans with the opposite pattern, you will need to get an adapter from the donor vehicle provided it has the same transfer case as your truck.
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
