transmission
Old Mar 25, 2015 | 08:41 PM
dbeene's Avatar
dbeene is on a distinguished road
Default transmission
my 95 blazer has a hard shift issue into 2nd gear I replaced the valve body and 1-2 accumulator and the 3-4 accumulator my question is does the piston go towards the spacer plate or towards the housing? same for the 3-4 my book shows it differently than it is now
Old Mar 27, 2015 | 05:47 PM
Tranzman's Avatar
Tranzman is on a distinguished road
1-2 accumulator, spring in housing first then the piston. 3-4 I put the spring in the case then the piston. this gives it the firmest 3-4 feel you can get without any further modifications. basically both pistons end up close to separator plate.
Tranzman
Old Mar 27, 2015 | 07:29 PM
dbeene's Avatar
Thank you for the info that's the way I have them only thing is it hits so hard at any speed makes me think I'm going to break something
Old Mar 27, 2015 | 07:32 PM
dbeene's Avatar
There are 2 springs under the 1-2 piston if I pulled the inner spring out would it not hit so hard?
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
