Transmission 96 4X4 Blazer 4 door
Old Nov 9, 2011 | 11:14 AM
BigDave_56's Avatar
BigDave_56 is on a distinguished road
Default Transmission 96 4X4 Blazer 4 door
New member here, hello to all. Hope to get some help with my daughter's little truck on the cheap. I'm experienced with racing engines (street/drag) in my youth, but know little about trannys. Have two kids
in school at the university level, so I need to fix this myself (short of a R&R) to afford the repair. Paid 3,000 three years ago, and have done minor repairs so far, well if you consider a fuel pump minor. Well here are the particulars...
1996 4 door Blazer 4X4 will not shift past second gear. Vortec V6 will break loose rear tire (in any forward gear position) with gas mashed and brakes applied. Fluid level is good, pan has small leak. Will auto & manually downshift to first gear and up to second, but refuses to go beyond that 2nd gear. I hopeful for a simple drop of the pan and change out a seleniod or something. Thanks in advance for your input. BigDave
Old Jan 8, 2012 | 09:24 AM
billyw88's Avatar
billyw88 is on a distinguished road
check the speed sensor or the transmission , my 96 blazer did the same thing and i changed it out and it shifted out perfece
Old Jan 8, 2012 | 10:04 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Check for trouble codes. If you don't have a scanner you can take the truck to an auto parts store that offers free scans. If the transmission is setting a code that can help you narrow down the possibilities of what might be wrong.
Old Jan 11, 2012 | 04:03 AM
Moses's Avatar
Moses is on a distinguished road
My son's 96 Blazer LT was not shifting right when we first got it (3 weeeks ago) when in (D) overdrive but shifter find manually 1st, 2nd, D. New filter and fluid and some Lucas Trany treatment took care of all the problems.
Old Jan 28, 2012 | 12:57 PM
cardude59's Avatar
cardude59 is on a distinguished road
sorry to be the bearer of bad tidings, but i also have a 96 blazer the shifts fine 1=2 then when time to shift to third it just freewheels,like its in neutral. the shift solinoids are working because it is trying to shift but the clutch pack is burned up. i am assuming the the speedo works properly. if it does then its rebuild time! sorry to say.
Athlon2012
Dec 16, 2014 11:35 PM
hlaverty06
Mar 23, 2014 09:25 AM
Guardian1014
Jul 11, 2012 03:31 PM
sfesenko
Nov 30, 2008 08:55 PM
dropd4door
Feb 10, 2006 02:34 PM
