Transmission Disorder
Old Jul 7, 2015 | 05:12 AM
  #21
newguy's Avatar
You may know already but you`ll need a new gasket to mount the transfer case to trans also . dealer item, will need VIN number
Old Jul 9, 2015 | 12:10 PM
  #22
snuffy's Avatar
snuffy is on a distinguished road
I knew I needed the gasket but didn't know it was a dealer item. Thanks
Do you remember what rebuild kit you used?
Old Jul 9, 2015 | 07:32 PM
  #23
newguy's Avatar
sorry cant think of it ,but if I remember I`ll let you know
Old Jul 11, 2015 | 11:58 AM
  #24
snuffy's Avatar
Default I think I found my failure.
So I am starting to put this thing back together. I get to the input housing and load all the clutch packs. To test the operation of the pistons you apply air in the feed holes in the shaft. When I applied air to this hole (3-4 clutch pack) the piston moves and the clutches engage but there is air blowing past the orifice cup plug in the housing, It's the hole in the housing to the right of my hand. I don't think there should air leaking past that cup plug, am I wrong?
Input housing
Air testing.
Attached Thumbnails Transmission Disorder-blazer%2520trans%2520assembly%25201%2520004_zpsgfptqb5n.jpg   Transmission Disorder-blazer%2520trans%2520assembly%25201%2520008_zpsq0umlakj.jpg
Old Jul 11, 2015 | 01:49 PM
  #25
10-78 edac's Avatar
10-78 edac is on a distinguished road
Old Jul 11, 2015 | 04:07 PM
  #26
snuffy's Avatar
Ah so I am wrong, and I just watched that video too.
Thank you so much.
On with the build.
Old Jul 11, 2015 | 10:22 PM
  #27
10-78 edac's Avatar
I'm about to do the same thing. What kit did you end up getting?
Old Jul 11, 2015 | 11:47 PM
  #28
snuffy's Avatar
Old Jul 12, 2015 | 02:48 AM
  #29
newguy's Avatar
I like the way your doing this, taking your time. Its gonna
work fine when done
Old Jul 12, 2015 | 10:48 AM
  #30
10-78 edac's Avatar
I am definitely gonna upgrade the "sun shell gear" while I'm in there.
