Transmission Filter Seal Removal.
Old Feb 27, 2012 | 12:05 AM
bowtie-72's Avatar
bowtie-72 is on a distinguished road
Default Transmission Filter Seal Removal.
OK quick, stupid, question. Does anyone know of an easy way to get the original factory filter seal out without scratching/damageing the bore? Normally I would just pry an old seal out with a screwdriver, but it is recessed and there isn`t anything to pry against. I have always left the seal alone just for this reason, but with almost 300,000 miles I thought I should change it. I tried to use a small offset screwdriver but all I did was tear the rubber and it did not budge. Now I am commited. Thanks.
Old Feb 27, 2012 | 02:19 AM
Park's Avatar
Park is on a distinguished road
On my 98 my buddy used a little hook/pick tool that looks like a dentist tool to grab it from the top lip and pull down. Took him about 10 minutes to work it out but he didn't damage a thing besides the old seal.
Old Feb 27, 2012 | 04:56 AM
mr.vls's Avatar
I use a scribe to pull the seal out. Takes less than 10 seconds.
Old Feb 27, 2012 | 05:29 PM
bowtie-72's Avatar
Thanks guys, I have a small pick. I thought it would be too wimpy to do the job, but I will try it. Sometimes you just need some confidence. Thanks, Jeff.
Old Mar 1, 2012 | 08:08 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
I used a small screwdriver and kinda tapped one side up in a little farther which gave me a lip to bend the seal. Seemed to work well without scratching the bore.
latunguley
Nov 17, 2014 09:15 PM
ElevenevelE
May 4, 2012 12:15 PM
blueblazer2002
Dec 24, 2011 08:32 PM
litterbug
Mar 7, 2011 09:14 PM
GMC_Jimmy_13
May 4, 2009 01:43 AM
