transmission or sensor?
Old Mar 1, 2012 | 06:13 PM
jkfrost77's Avatar
jkfrost77 is on a distinguished road
Default transmission or sensor?
hi, im new to this forum so if im posting in the wrong place just tell me.
i bought my first blazer and love it and this site has been more than helpful, so thanks.
my problem: the rpms rev up high before it will change gear (sometimes it doesnt change gear at all) but if i pull over and cut the truck off then cut the truck back on it will change gears perfectly. (i cut the truck off then immediately cut it back on)
someone told me to change the tps so i did. it still does the same thing and now the 'service engine soon' light is on. i dont know if there is a proper way to replace the tps so maybe i did it wrong or if its not the tps at all.
its a 1998 chevy blazer LS v6 4.3L it has 250,000 miles. the transmission was rebuilt at 150,000 miles
thank you. ill take any advice you guys have. thanks
Old Mar 1, 2012 | 06:25 PM
pettyfog's Avatar
I think you should go to AZ or the like and have the code(s) pulled
Old Mar 1, 2012 | 08:38 PM
jkfrost77's Avatar
thanks pettyfog, im just afraid that if i keep driving it (even to az or somewhere) then im just making it worse and worse. i was hoping to fix it in my yard before i drive it at all. but your right i should just bite the bullet and take it up there. thanks
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
