Transmission help
Old May 28, 2018 | 11:52 PM
Daveed's Avatar
Daveed is on a distinguished road
Default Transmission help
so the other day my 2001 blazer threw codes for both shift soleniods so I replaced them and it seems to be better but it runs high rpms in third gear still.
Old May 29, 2018 | 05:46 AM
GreenBlazer2002's Avatar
Have you been through enough drive cycles for any new codes to set yet?
Old May 29, 2018 | 08:58 AM
Daveed's Avatar
I drove it around for at least 30 minutes after replacing the solenoids
Old May 29, 2018 | 09:14 AM
Transman304's Avatar
What code numbers did you get? Will it shift past third into fourth?
Old May 29, 2018 | 09:15 AM
Daveed's Avatar
I don’t remember the codes now. But no it won’t shift from third to fourth
Old May 29, 2018 | 09:21 AM
Just strange to show both solenoids at once. What was it doing before solenoid replacement? What condition was the fluid when you dropped the pan?
Old May 29, 2018 | 09:23 AM
Daveed's Avatar
I couldn’t feel it shift into anything it was running high rpms
Old May 29, 2018 | 09:29 AM
It sounds as if it is limp mode. Third gear. Check the fuse. Does the indicator on the dash light up to tell you what gear you are in?
Old May 29, 2018 | 09:30 AM
Daveed's Avatar
no I don’t think it does. I’ll check that fuse
Old May 29, 2018 | 06:36 PM
Daveed's Avatar
fuse for limp mode isn’t blown.
