Transmission help
so the other day my 2001 blazer threw codes for both shift soleniods so I replaced them and it seems to be better but it runs high rpms in third gear still. |
Originally Posted by Daveed
(Post 690839)
Originally Posted by GreenBlazer2002
(Post 690849)
Have you been through enough drive cycles for any new codes to set yet?
What code numbers did you get? Will it shift past third into fourth?
Originally Posted by Transman304
(Post 690856)
Just strange to show both solenoids at once. What was it doing before solenoid replacement? What condition was the fluid when you dropped the pan?
(Post 690858)
It sounds as if it is limp mode. Third gear. Check the fuse. Does the indicator on the dash light up to tell you what gear you are in?
(Post 690860)
(Post 690861)
no I don’t think it does. I’ll check that fuse |
| All times are GMT -5. The time now is 11:39 AM. |
