Transmission hestation going to first and hard shift to 2nd
Old Dec 4, 2018 | 05:16 AM
sgilbert14's Avatar
sgilbert14 is on a distinguished road
Thanks looking at a replacement probably. A friend of mine owns a salvage yard and thinks he has a couple low milage ones. Good thing is that this is a 2nd car and is only driven once a week or so. I also added the Lucas slip fix additive when I refilled it.. I hope to get to spring beofre I have to deal with the issue again..
Old Dec 4, 2018 | 07:28 PM
sgilbert14's Avatar
well starting to lean towards a replacement tranny... went for a real drive today and it wants to rev up instead of going into 3nd. If I let off the gas it shifts in correctly and downshifts are fine, I been researching this and see that it could be that the new solenoid that I put in is bad or that the filter never set correctly.. pain in the *** and I will pull the pan and look this weekend, but not sure if there is anything else to look at.. but I am finding mostly this "When the 4l60 trans shifts from 1st to 2nd and then when it tries to go to 3rd the engine just revs up, the 3-4 clutch has failed and the trans needs to be rebuilt. Sorry." which sucks and will = blazer sitting for sometime..
Old Dec 4, 2018 | 08:14 PM
odat's Avatar
What does it do if you manually shift gear by gear it instead of just putting in drive ?
Old Dec 4, 2018 | 09:03 PM
sgilbert14's Avatar
works fine
Old Dec 4, 2018 | 10:08 PM
odat's Avatar
Just guessing here but if it shifts fine manually without letting off the gas you may have a small partial sludge plug off in the valve body.
You could prob get by for awhile driving it around and manually shifting till a transplant trans is located but for this one the clutch packs are past worn and damage is already done.
Old Dec 5, 2018 | 05:59 PM
sgilbert14's Avatar
Well I am on the list for a rebuild.. with holiday expenses and a new furnace install it will be a bit but found a shop here thet will pull, rebuild and installl with warrenty for 950..
Old Dec 5, 2018 | 07:04 PM
odat's Avatar
That's not too bad a price with them doing all the work - And ya I'm well aware of projects getting put on the back burner due to other things - luck to you.
Old Dec 5, 2018 | 08:09 PM
sgilbert14's Avatar
thanks.. thought of pulling and installing it myself but not sure what I would be getting into. I would be working with it on jack stands... if it wasn't the big of a deal, changed the tranny on my Mazda 626 in much worse conditions, I could get it rebuilt for 450
Old Dec 6, 2018 | 12:13 PM
Transman304's Avatar
Just curious as to what the rebuild consists of if you would care to share? Thanks.
Old Dec 6, 2018 | 08:47 PM
sgilbert14's Avatar
Well, seeing that I have a 2nd car and time I have decided to give this a go at doing it myself. Pulling and installing the tranny myself will same me over 500... any "watch outs" that I should know of.. thanks
