Transmission issue???
Old Sep 6, 2019 | 05:33 PM
harrisons3's Avatar
harrisons3 is on a distinguished road
Default Transmission issue???
I just recently purchased a 2000 Blazer 4x4 4 door, and while driving it 3rd and 4th gear went out. The car will try to shift into third then just act like it is in neutral and start revving. Now, this is where it gets interesting. First i checked the dipstick and the fluid was still bright red and smelled just fine. My second action was just to replace the transmission since i already had a 4l60e (which i knew ran and shifted just fine) and not to my surprise it had the exact same issue. I cant fix this issue no matter what ive tried, there is no check engine light and ive gone through 4 sets of shift solenoids. Im in need of help send me any ideas of how to get this car back to shifting, thank you!
Old Sep 7, 2019 | 12:45 AM
Losing 3rd and 4th is often an indication of the 3-4 clutch pack having gone bad. It is not an uncommon problem.
Old Sep 7, 2019 | 08:07 AM
harrisons3's Avatar
I thought the same thing as you, until I put in another working transmission and when I went to drive I had the exact same issue. That’s why I am leaning more towards electrical. The only issue is I know absolutely nothing about the electronics on these vehicles.
Old Sep 7, 2019 | 08:53 AM
okaussie's Avatar
okaussie is on a distinguished road
I lost the 3-4 clutch in 3 new transmissions in my 02 Crewcab. Now on number four . Total miles on truck is over 230K.
Bill
Old Sep 7, 2019 | 01:02 PM
Was the replacement transmission was used? How many miles did it have? If it had its fluid drained and refilled with fresh fluid then perhaps the new fluid contributed to the second transmission's 3-4 clutch pack failing. I do not have direct experience with this but I have seen it mentioned many times on this forum.
Old Sep 7, 2019 | 01:34 PM
okaussie's Avatar
In my case, every one was brand new. The original lasted about 100k before it went bad. Then I was getting 30-40k out of the others. Right now it has about 40k and is still working...
Bill
Cornfed8827
Mar 30, 2018 03:56 AM
FIVEHORSE
Aug 13, 2015 07:06 PM
melliferal
Dec 5, 2013 09:05 PM
Blanc01
Nov 23, 2013 11:06 AM
chadd77
Apr 19, 2013 02:02 PM
