Transmission Issue: Please Help
Old Nov 6, 2017 | 04:19 PM
mmtilton's Avatar
mmtilton is on a distinguished road
Default Transmission Issue: Please Help
OK you Blazer experts, here's one for you: I have a '98 4X4 Blazer that has a transmission problem. The symptoms point to the VSS. The transmission won't shift and the speedometer doesn't work--that is until it warms up after driving a couple of miles (very slowly). Then it shifts fine and the speedometer works as though no problem exists. However, I hooked it up to a code reader and it gave the code : PO 740 Torque Converter Circuit Clutch / Open. I know this is not the VSS code. Is it possibly giving the wrong code or what? Thank all of you for your input!!!
Old Nov 7, 2017 | 07:06 AM
Transman304's Avatar
The code reader is probably giving you incorrect information. Need to have it scanned with proper OEM software. Be great if you could get a live data stream to actually watch what is happening. I believe that there are 3 possibilities on transfer cases in that year so make sure you get the parts for your vehicle. Good luck!
FIVEHORSE
Aug 13, 2015 07:06 PM
astro209
Aug 25, 2013 01:24 PM
blazer888
May 18, 2010 03:54 AM
rogggg1020
Nov 11, 2008 08:05 AM
1badSRAD
Sep 14, 2006 04:31 AM
