Transmission issues
Old Oct 9, 2018 | 02:59 PM
1997chevblazer's Avatar
1997chevblazer is on a distinguished road
Default Transmission issues
Hello I have a 1997 blazer with a 4l60e
theses are the codes I pulled from it
po740 torque converter clutch open circuit
po753 shift solenoid a
po758 shift solenoid B
po785 shift timing solenoid
If I pull The transmission fuse it gives me third year and reverse but with the tranny fuse in I only have reverse is there something I can do to fix it or is it just done for? What do you guys think? Thank you
Old Oct 9, 2018 | 03:41 PM
Transman304's Avatar
You have lost the 12 volt signal to the transmission. Are the gear indicator lights in the dash cluster working?
Old Oct 9, 2018 | 06:22 PM
It is a console shift But the Indicator lights on the consul beside the shifter are working
Old Oct 9, 2018 | 06:23 PM
There was a bit of a clunk when I lost all the gears but I can still move it in third gear with the transmission fuse pulled
Old Oct 9, 2018 | 09:04 PM
The transmission is in limp mode with no power to it. It will have 3rd and reverse with no power to it by design. You most likely have an electrical issue. Do proper diagnostic on it before throwing parts at it. Could be just a bad ground wire. Need to have it on a live data stream to see if PCM is commanding the correct information.
Old Oct 10, 2018 | 06:19 AM
Any idea what to check first?
Old Oct 10, 2018 | 01:27 PM
Have it scanned with the proper equipment with OEM software capabilities. Not a code reader. Probably a transmission shop is your best bet.
Jeffvader
Mar 7, 2019 09:27 AM
88blazerzac
Jan 2, 2019 01:05 AM
DavidSjr
Jul 19, 2018 03:49 PM
Daveed
May 29, 2018 10:23 PM
