Transmission leaks from vent tube
Old May 28, 2009 | 10:54 AM
I suspect that your fluid has frothed (entrapped air), raising the level on the stick. This is another problem in and of itself. How well does the transmission shift/perform?
Old May 28, 2009 | 11:25 AM
Denominator's Avatar
Denominator is on a distinguished road
Thats the strange part of it, it performs very well. No hard shifting, no slipping, I can hardly feal it shifts.
Old May 28, 2009 | 02:58 PM
If your trans fluid is foaming, it could be a sign that the fluid has reached the end of its life. I would do a full service on the transmission while you are doing the repair on the transfer case.
Old May 29, 2009 | 04:58 PM
Thanks for the information. I will give it some TLC, maybe it's not to late, hope so
Old Jun 3, 2009 | 05:33 PM
Originally Posted by swartlkk
Is this the vent tube at the firewall near the transmission dip stick tube or the one on the transmission under the truck? The one on the transmission is not connected to anything. The breather that is near the dip stick tube for the trans is actually the vent for the transfer case vacuum switch.
If it is the breather near the dip stick tube, then the problem is your transfer case input seal is leaking transmission fluid into the transfer case and, coupled with a leaking vacuum switch, is pushing fluid up into the vent line. The problem with this possibility is that you most likely will have transmission fluid throughout the vacuum system as well...
Please clarify where it is leaking from.
I got a P0507 code to day, can this be because of the vacuum switch?
Old Jun 3, 2009 | 06:51 PM
P0507 - Idle Control System RPM Higher Than Expected
Doubt it.
Old Jun 3, 2009 | 06:59 PM
This code poped up not when idling, but when I hit around 30 mph.
That seems strange to me. Have read the P0506/0507 explaind, and will go thru the possible faults described there.
razman
Dec 30, 2014 10:14 PM
builder125
Apr 17, 2011 09:20 PM
builder125
Apr 4, 2011 05:27 AM
jbelllive
Jun 21, 2008 11:25 PM
v8vairman
Apr 12, 2006 01:43 PM
