Transmission Limp Mode and 2 different tire size?
Old Jan 30, 2017 | 09:39 AM
Transman304's Avatar
Transmission Limp Mode and 2 different tire size?-img_3050.jpgDid you have to struggle to get the pan down away from the transmission at the crossmember? I ask because the plastic piece looks like it is part of a shift solenoid which is easily broken when removing the pan. As far a testing the PRNDL switch I would guess that a continuity test would work. Never have tested one. I follow the data stream of it on the scanner.
Old Jan 30, 2017 | 10:30 AM
LesMyer's Avatar
Originally Posted by Transman304
Attachment 29376Did you have to struggle to get the pan down away from the transmission at the crossmember? I ask because the plastic piece looks like it is part of a shift solenoid which is easily broken when removing the pan. As far a testing the PRNDL switch I would guess that a continuity test would work. Never have tested one. I follow the data stream of it on the scanner.
Hey Transman304. Definitely appreciate your efforts. You're new but it seems to me that you've been giving very good advice here on the Blazer Forum. We need a good transmission man active here. Just Sayin'...
Old Jan 30, 2017 | 10:51 AM
PSS-Mag's Avatar
PSS-Mag is on a distinguished road
Wow you are good transman. Yes I did struggle there as a matter of fact. I didn't get rough with it by any means but took a while to find and get it into the right position to slide out.
Well I think at this point do to time restraints or lack of free time on mine. I might be better off to take it to a shop with the right equipment and get an accurate diagnosis. I have no idea what the values should be or which pins to test so probably worth it to pay someone who does know or has the equipment.
Old Apr 27, 2017 | 09:37 AM
PSS-Mag's Avatar
OK found the problem and it's fixed.
wierd as it is, this one was a dented transmission pan. Attempted to straighten it out but was unsuccessful. So grabbed one from salvage yard. It had actually broke one shift solenoid and the other was grounding out. Only realized after someone noticed a tiny burn mark in bottom of the pan. New pan and two new solinoids and it shifts like a dream.
Thanks for all the help transman! This was a wired one. I can only assume that the previous owner banged it when they installed the transmission. It was such a uniform dent it looked stamped from the factory.
Old Apr 27, 2017 | 02:04 PM
Glad it all worked out for you! Happy motoring.
Old Apr 27, 2017 | 08:52 PM
PSS-Mag's Avatar
Thank you and thanks for all your help!
may all your gears keep thier teeth and your fly wheel stay round. Hopefully I can help you somehow in the future to repay you.
Old Apr 28, 2017 | 12:56 PM
Love the quote! May use that as a tag line if you don't mind?
Old Apr 29, 2017 | 07:21 AM
PSS-Mag's Avatar
That's perfectly fine with me!
Drambo94
Oct 20, 2015 10:32 PM
dannyb91979
Oct 1, 2013 01:10 PM
cakes227
Nov 30, 2010 10:35 AM
BlackFireLS4.3
Jan 29, 2010 10:00 PM
deadgoon20
Oct 30, 2008 02:03 PM
