transmission only in 2nd
Old Dec 29, 2012 | 08:54 PM
dawnie's Avatar
dawnie is on a distinguished road
Default transmission only in 2nd
Hi I joined this forum hoping that someone out there would have some idea what is going on with my 2000 blazer. I had to replace the transmission about 2 weeks ago. Put another one in and the truck ran absolutely perfect...until today. Today I was backing my small trailer into my brothers yard, we had snow here today so I put it into 4lo and went to back up it felt like I hit something, and the front tires werent spinning.
I put it in automatic 4x4 and it went. Afterwards when I was leaving the
truck only goes a few minutes and then seems like it is in neutral it revs up but goes nowhere. I have to shut it off and wait a minute or two and then start it up again and it will go so far and then do the same thing. It did it 5 times in the 2 mile ride home. I looked online read about limp home mode and checked and if I put it in 2nd gear it goes but what I read says if it is limp home mode you can only go in second gear (which I can)
but you should have reverse (which I dont) Now when I shut it off and wait and restart it, it all shifts fine and I have reverse then when it seems to go into neutral and wont go unless it is in second gear I lose reverse but when I wait and restart it it all comes back shortly. anyone have any idea?
Old Dec 31, 2012 | 05:31 PM
Is the Service Engine Soon light on? If so, what DTC's, (Diagnostic Trouble Code) are in memory? Autozone, Advance auto parts & O'Reilly will retrieve them for free. Write them down in the order they are retrieved and post them here.
Old Dec 31, 2012 | 08:44 PM
aa21830's Avatar
aa21830 is on a distinguished road
This thread lists some of the common symptoms and troubleshooting:
https://blazerforum.com/forum/tech-a...ilation-37689/
Lack of 3rd and 4th gears is worn out "3-4" clutch. Seems odd that would be happening, though, if you just replaced the tranny. My 3-4 clutch went out at >200k miles.
steelcityneal
34
Oct 6, 2017 06:10 PM
cbrinkley83
Jun 24, 2015 08:21 PM
hunterswyv
Sep 14, 2013 12:43 PM
bearsfangb1
Mar 24, 2010 07:04 AM
ABN31B
25
Nov 19, 2009 08:47 PM
