Transmission pan filter seal
Old Sep 15, 2010 | 09:12 PM
ElevenevelE's Avatar
ElevenevelE is on a distinguished road
Default Transmission pan filter seal
Ok, so im replacing a leaky transmission pan gasket, i've actually already replaced it, but i messed up somewhere so it still leaks. I have an idea where i messed up so im removing the pan again to fix my goof. But the first time around i didnt change the transmission filter seal cuz i was in a hurry and didnt really know how. This time around i would like to change the seal, but my problem is that i dont know how to get the thing out. The Haynes manual didnt describe it too well, but from what i hear you have take a screwdriver to the outer lip and pound it loose with a hammer...which didnt sound too safe to me, especially when they tell you to be careful to not gouge the housing. I also saw online people talking about a seal puller that is specially designed for this. Does anyone have any ideas or suggestions on how to go about this? Or even know where i could find that seal puller? Thanks in advance
Old May 2, 2012 | 02:46 PM
ozzman39's Avatar
ozzman39 is on a distinguished road
Id like to know too
Old May 2, 2012 | 06:45 PM
4x4blazerguy's Avatar
First off I guess your working on a 4L60E. The filter will pull out with a little effort a some twisting. I never replace the o-ring unless I have reason to believe it is damaged. If the filter fits nice a snug it most likely is OK.
As for the pan leak I have posted this before but most pan leaks are because of overtightened pan bolts. What they do is bend the pan up around the holes so take a ball pene & flatten the holes or dent them out some. When you tighten the pan the bolts will pull the hoses flat.
Old May 4, 2012 | 11:18 AM
ozzman39's Avatar
I used a Pilot Bearing puller to get it out worked great
advanceautoparts rents them
Old May 4, 2012 | 12:15 PM
chris015's Avatar
Like he said. If the filter goes in with a snug fit,leave it alone. If you arent careful you can beat a gouge and cause fluid to leak between the seal. Ive never had a change one out.
globalaccessacc
Jul 5, 2013 04:08 AM
ComputerNerdBD
Oct 12, 2012 12:15 PM
bowtie-72
Mar 1, 2012 08:08 PM
blueblazer2002
Dec 24, 2011 08:32 PM
GMC_Jimmy_13
May 4, 2009 01:43 AM
