transmission problem
Old Jul 26, 2012 | 07:10 PM
panicman57's Avatar
panicman57 is on a distinguished road
Default transmission problem
2000 blazer shifts fine manually. does not seem to shift on its own smoothly, sluggish until 30 mph. is there a cable adjustment or are there cylinoids in trans? help help getting ready for vacation thanks in advance tony
Old Jul 26, 2012 | 10:26 PM
chrisgascoigne's Avatar
chrisgascoigne is on a distinguished road
Tony,
My blazer has this same issue. To answer you question, Yes there are 2 shift solenoids and A and a B. I replaced both of these and mine ran fine for about 100 miles then started up with the same problems. Dunno why tho which is why I am back here.
To change your solenoids you need to drop you transmission fluid pan. That is where they reside
Old Aug 14, 2012 | 10:19 AM
Charger67's Avatar
Charger67 is on a distinguished road
Have you guys checked all your grounds on the vehicle....also try changing the speed sensor. That'll rule out computer control glitches.
Change out the tranny fluid for new fluid and put a bottle of Slick 50 tranny fluid treatment in it to thicken up the fluid/ increase pressure a little inside the tranny.
If you are really brave spend the $177 and get the tranny rebuild kit from Summit Racing and only drop your pan and replace the goodies/ seals for the valve body on the bottom of the trans. If yer brave. Make sure you put the little ***** inthe right spots.
Old Aug 14, 2012 | 05:46 PM
mychevyisntheavy's Avatar
mychevyisntheavy is on a distinguished road
u all need to check the trans fuse first in the fuse box. if there is no voltage on white wire side then ur ingtion switch is bad. check for votage first.
DBo42098
Aug 25, 2009 05:11 PM
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
Cuppy
Jul 21, 2006 11:25 PM
jermag24
Engine & Internal
Jan 6, 2005 10:56 PM
