Transmission problem, need some help
Old Sep 1, 2010 | 04:06 PM
sifd4x4's Avatar
sifd4x4 is on a distinguished road
Default Transmission problem, need some help
For the past few weeks my Blazer has been doing something weird with the transmission. When riding right around 40mph not really accelerating just staying at that speed my tranny wants to act like its slipping or doesn't want to pick a gear. I tried doing it while leaving it in 3rd and it still does it. The rpm's will go up and down a few 100 rpms and if you let off or accelerate it will stop. Is this a sensor maybe or something in the transmission?
Old Sep 1, 2010 | 06:19 PM
Sounds like your torque converter is going in and out of lock up. Around 40mph is the speed where lockup occurs and the torque converter will lock in both 3rd and 4th.
The next time this occurs, tap the brake lightly (just enough to turn on the lights, but not slow you down). This will cause the torque converter to unlock.
Old Sep 1, 2010 | 07:26 PM
sifd4x4's Avatar
Alright I can try that. If that stops the problem does it mean I need a new torque converter or something else?
Old Sep 1, 2010 | 07:39 PM
It could just be something you have to deal with at that speed. You could try running a bit slower than 40 or a bit higher (say 45). 40MPH is just a bad speed for these torque converters.
Also, you could try measuring the output from your TPS sensor. If the TPS sensor is worn at that throttle position, it could cause an erratic reading which the PCM would interpret as you opening/closing the throttle, causing the problem.
Old Sep 1, 2010 | 07:50 PM
sifd4x4's Avatar
Alright I will try and look at the TPS sensor and see if I can cure the problem.
Old Sep 4, 2010 | 06:04 PM
Have you had a chance to test the TPS yet sifd?
Wyatt Abshire
Jul 12, 2012 08:27 AM
blueblazer1982
Dec 22, 2011 07:38 PM
davidluzader
Mar 1, 2010 10:25 AM
scottyk
Mar 19, 2007 11:32 PM
goken50
Feb 13, 2006 04:35 PM
