700R4 Interchange
Old Sep 4, 2010 | 06:25 PM
Dark79K5's Avatar
Dark79K5 is on a distinguished road
Default 700R4 Interchange
Hello everyone. Great forum. I have a question regarding the 700R4 ( 4L60 ? ) in my 79 K5. It came out of an 88 Suburban 5.7 TBI. It has lost the D/OD bands or clutch packs. It just free wheels. I have found a brand new trans that was installed in an 88 GMC 4x4 pick up. My question(s) is: Will it fit - the output splines,tv cables,etc., and are the converters interchangeable? I'm on a tight budget so I would like to reuse my converter if at all possible. Any input would be greatly appreciated before I spend the money. I haven't seen the new transmission in person yet so I can't really provide any specifics at this time about it. Thanks and have a safe holiday weekend!
Last edited by Dark79K5; Sep 4, 2010 at 06:29 PM. Reason: left out pertinent information
Old Sep 4, 2010 | 06:26 PM
It should be pretty much identical (bad bands aside). You shouldn't have any problems using it.
Old Sep 4, 2010 | 06:33 PM
Dark79K5's Avatar
Talking
Wow! That was quick! Thank you so much. Gotta love Chevy guys.....
Old Sep 4, 2010 | 06:53 PM
I guess I made an assumption that both were 4wd. Was that the correct assumption?
Also, on your torque converter, hopefully none of the junk from the bands disintegrating made it into the TC.
Old Sep 4, 2010 | 09:01 PM
Dark79K5's Avatar
You would be correct. They are both 4wd and I know mine is non electronic. As for the TC, I hope you are right. The trans shifts nice and firm from 1st to 2nd, and relatively firm from 2nd to D, where it hits for a second, then the motor just winds to the moon. I know that it could also be that the hole that gets stamped from the factory in the seperator plate may not have been punched ( Chevrolet stamped them in multiples at a time and I have heard quite a few made it past QA without this hole ) and that may have caused the failure due to improper fluid pressure. I thank you again brother.
DFINE160
Dec 7, 2009 12:17 PM
Roosawl
Oct 22, 2009 12:05 PM
MNHawk
Dec 21, 2006 09:38 PM
MIKE82
Nov 15, 2006 02:16 AM
ginobass
Sep 11, 2006 05:16 PM
