Transmission rebuild
Old Apr 3, 2016 | 09:37 AM
skydyvr's Avatar
skydyvr is on a distinguished road
Default Transmission rebuild
Recently bought a blazer off Ebay. Engine runs great but transmission shifts from 1st to 2nd fine but no 3rd or 4th. Got code p0753 so replace shift solenoids A and B replaced filter flushed transmission. Code p0753 is now gone but still no 3rd or 4th. When transmission is at operating temp read full when is cold reads way over full. What in the world?
Old May 12, 2016 | 09:22 AM
skydyvr's Avatar
Pump and input drum seem locked together and came out as one. Did I miss some thing or are they just stuck? This is from a 2001 s10 Blaze?
Old May 13, 2016 | 08:40 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Did you pull the "O" ring? Around 2:23
Old May 31, 2016 | 10:15 PM
skydyvr's Avatar
Transmission came from 2001 blazer 4x4 bought cheap because of transmission. Rebuilding it but both input shaft and separator plate seem to be 1993 to 1999.Separtor plate has a spot where a ball bearing goes that is built up. Tag reads 1TAD and torque converter has tag that reads DCNF 2420. Seems to have been rebuilt before and one trust bearing and the 3 4 clutch release springs were missing. Any insight would be greatly appreciated
Old Jun 1, 2016 | 09:30 AM
skydyvr's Avatar
Question is, is it possible that a transmission built in 2001 would have what appears to be a 1993 to 1999 input shaft and separator plate
Old Jul 14, 2016 | 09:04 AM
skydyvr's Avatar
Thanks for the help in rebuilding transmission. As it turns out all works as if it were new. Again thank you
blazintrailz
Dec 5, 2010 09:11 PM
Seeker
Oct 24, 2010 06:39 PM
TomSawyer
Mar 3, 2010 10:02 PM
jgilk1
Feb 1, 2008 12:03 PM
88s10Blazer
Dec 25, 2007 09:29 PM
