Transmission runs rough only when I use my A/C or Heat.
Old Aug 24, 2013 | 09:37 AM
alands26's Avatar
alands26 is on a distinguished road
Default Transmission runs rough only when I use my A/C or Heat.
Hey guys,
Yes its as simple as that. I have a 2004 Chevy S10 Blazer...when I run the A/C or Heat...it shifts really hard...or sometimes not at all. I have to pull over shut the A/C or heat off and start the engine up again. Other than that it shifts just fine. WTH? I don't know it its related but when It gets hot outside. 85 deg f or above...I have to wait a few minutes before I can turn my key all the way off. I can shut the engine down but the ignition won't turn all the way back. It never happens unless it is hot outside. Thanks
Old Aug 25, 2013 | 08:20 AM
alands26's Avatar
anybody?
Old Aug 25, 2013 | 08:50 AM
newguy's Avatar
may not be your tranny. Also possible your trans is overheating. Clogged lines maybe
samot
Mar 25, 2020 02:41 PM
fnbutch
Jun 25, 2013 12:08 AM
Doctorvette
Nov 5, 2012 11:57 PM
zakm0n
Jan 10, 2011 11:42 AM
c10jm
Aug 12, 2008 05:34 PM
