Transmission seals
Old Aug 13, 2021 | 12:36 PM
nomoresubies's Avatar
nomoresubies is on a distinguished road
Default Transmission seals
My 2001 Zr2 trans is leaking into the transfer case. I've had the vehicle for 3 years now and the problem was just noticed recently. It seems to be getting worse rapidly. I have been told this is a common malfunction. How tough is it to pull these units and replace the seals? Everything seems to run OK other than the leaks. Should I attempt this or take it/them to a shop? Thanks.
P.S. As I continue to read about this I am now wondering if this is caused by the rear trans seal or the front transfer case seal?
kuntryrebel88
Nov 3, 2015 10:46 PM
chowell
May 6, 2014 09:34 AM
CJ8
Apr 5, 2012 05:54 PM
spaceapex
Aug 11, 2010 02:43 AM
chevyman09
Dec 7, 2008 07:58 AM
