Transmission shifts seem off?
Old Nov 17, 2012 | 08:00 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Pardon my bad memory
But one of our members had transmission trouble the other day and uses seafoam trans tune.He said it work nicely with very good results.So as an additive thats something you can try also.
Old Nov 17, 2012 | 03:53 PM
Jakeduece's Avatar
Jakeduece is on a distinguished road
That's always a thought. Thanks!
Old Nov 18, 2012 | 10:59 AM
Default I noticed on my truck the fluid is dark
The trans has been shifting erraticaly,sometimes shifting good sometime very soft or not even noticeable.I drained a couple quarts out it yesterday and what I seen didnt look good.I put a bottle of the seafoam trans tune and seems to be shifting better so far.I need a complete flush from what i can tell.I also notice my trans gets realy hot on long road trips.Hopefully I can by sometime without hurting my trans till I can get to it.
Old Nov 18, 2012 | 09:33 PM
Jakeduece's Avatar
That's interesting. How could you tell that your trans was overheating?
Old Nov 19, 2012 | 10:22 AM
Default RE:overheating
2 ways most noticable when I was driving it wouldnt shift and engine had lots of power but took more to keep up to speed.It hs left me stranded or I limped to a gas station or friends house on the way home from road trips.
Then I would pull the dipstick and literaly had steam coming out of the tube.As for the seafoam trans tune it stop working so Im going to have drain my fluid and add some lucus.I have a road trip coming up I got to make sure its shifting better.
Old Nov 19, 2012 | 10:51 AM
Jakeduece's Avatar
Oh I see. Is it possible that your tranny cooler lines are plugged, allowing your tranny to heat up?
I have a roadtrip coming up as well, I'm just hoping I fixed my engine overheat issue that I had the last time I made the trip. It's been great so far, but its a blazer, and blazers quite like to suprise you!
Old Nov 20, 2012 | 03:33 PM
Tranny lines arent plugged I flushed out fluid through them.I drained a couple of quarts of old fluid out.I put in a bottle of lucus and fesh bottle of ATF.I can tell a very noticable difference almost right away.A 200 mile road trip coming up so its going to have to do.My trans is just tired the cylinoids and boost valve need to be replaced along with the filter and fluid.When i can afford to have it done I`ll be on it right away.I never have enough time for myself Im always either working on my truck or the Jimmy.Now my hood latch is messing up and it wont close all the way.If I cant get it fixed intime to leave Im just going to chain it down.
Old Nov 20, 2012 | 03:38 PM
Jakeduece's Avatar
It's always something, isn't it?
Old Nov 20, 2012 | 04:17 PM
It sure seems that way.It never stops and I dont know how long my body is going to hold up.The pain is excusiating every day.
Old Nov 20, 2012 | 04:44 PM
BresBlazy's Avatar
BresBlazy will become famous soon enough
Hang in there...ALWAYS gotta take time for yourself, if something happens to you, then its all gone to ****....at least thats what I try to tell myself LOL
