Transmission or something else ?
Old Aug 23, 2009 | 06:27 PM
red blazer's Avatar
red blazer is on a distinguished road
Default Transmission or something else ?
I have a 1999 Blazer with the V6 in it, from a stop light i am getting a 2-3 second delay when I excelerate and then it kicks into gear and goes. It only does this when it gets fully warmed up, all other shifting is fine. Any help would be greatly appreciated, thanks for your time.
Old Aug 24, 2009 | 06:38 PM
red blazer's Avatar
I noticed today if I hold the brake and bring the rpm's up around 1000 it takes off just fine. Also the guy I bought it from told me the transmission was just serviced as in fluid and filter. Please help I am stumped.
Old Aug 24, 2009 | 08:20 PM
Sounds like the line pressure is dropping too far at idle and not properly holding 1st gear engaged.
Old Aug 24, 2009 | 09:08 PM
red blazer's Avatar
swartlkk, thanks for replying. What can I do to correct this problem ??? Thanks again.
Old Aug 29, 2009 | 07:28 PM
red blazer's Avatar
I had the line pressure checked Friday and everything else in the transmission and they said everything checked out ok except my two motor mounts, so I replaced them and it still does it but not as bad. Can anybody please help me with this problem ? Thanks
Old Aug 29, 2009 | 07:33 PM
Have you checked your transmission mount? I can't see the connection between the mounts and this type of behavior... What did the transmission shop say about the delay you are experiencing?
Old Aug 29, 2009 | 08:12 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Sloppy u-joint? Maybe the rear end needs servicing? Just throwing out ideas.
Old Aug 29, 2009 | 10:49 PM
red blazer's Avatar
The transmission shop thought it was from the motor mounts, but when I ask why does it not do it when it is not warmed up, he said if the mounts dont fix it to bring it back. Yes I will check the transmission mount. I am totally with you swartlkk, I dont see the connection either with the motor mounts. I am open to any ideas, thanks
Old Aug 29, 2009 | 11:00 PM
red blazer's Avatar
Transmission mount is good. Any other ideas ?? Please.
Old Aug 30, 2009 | 09:10 AM
number13man's Avatar
number13man is on a distinguished road
i have the same year as you and i am experiencing this problem as well. when i get the funds, i will have the transmission fluid changed. if that doesnt help, i will follow this thread and see how you fixed yours.
someone told me that shops do not like to changed the transmission fluid in an older vehicle because it can damage the transmission? is this BS or is there some truth to it?
