transmission swap day two
Old Jul 2, 2012 | 10:46 PM
adumsted's Avatar
adumsted is on a distinguished road
Default transmission swap day two
Yesterday I started the tranny removal process on my 2000 s10 4wd. I got the drive shafts and transfer case out of the way and got all of the harness connections undone from the transmission. Today was not as productive, I got the starter removed and the fuel line brackets undone, I got a late start about 3pm (girlfriends OB appointment) and I got the front six exhaust manifold nuts undone on the front of the Y, now I'm am stuck because I have two incredibly rusted nuts clinging to the exhaust at the rear. PB blaster has got me through the rest of the crud, but I'm thinking a torch will be handy for these. If anyone has a trick it would be helpful, its kind of a pain to be held up on something so small. Also the cooler lines are a little stuck, I've got PB blaster on those too, this Iowa heat is just wearing on me.
Old Jul 2, 2012 | 11:43 PM
warthogdriver's Avatar
when i did mine i left the manifolds on the block and just unbolted the 'y' pipe from the manifolds.
Old Jul 3, 2012 | 08:42 AM
adumsted's Avatar
Yeah I just removed the nuts connecting it to the manifold, I'm stuck now at the other end of the y connected to the muffler.
Old Jul 3, 2012 | 09:20 AM
rexmburns's Avatar
Super Moderator
Just torque the s*** outta them until they break off and once they are broken you should be able to tap them out with a punch or you may have to drill them out. Then just put new nuts and bolts in there. I have done this in the past on my Land Rover.
Old Jul 31, 2013 | 07:03 PM
jasaon's Avatar
jasaon is on a distinguished road
if you working close to the ground you cant get exhaust out anyway i had to cut in two to completely remove i'm not a mechanic but i replaced trans by my self had exhaust welded back together good luck make sure you cut in good straight place
Blazerdazed
Oct 18, 2010 07:58 PM
behemoth
May 18, 2010 08:53 PM
The_Beast
Mar 27, 2010 06:32 PM
uncledenny
Oct 28, 2009 04:38 PM
Teisco
Feb 26, 2008 09:27 PM
