Transmission swap question?
Old Dec 1, 2018 | 11:06 PM
biggermrbrute's Avatar
biggermrbrute is on a distinguished road
Default Transmission swap question?
Alright guys, I’ve got a 2000 Blazer (4x4, 4 door) with a bad transmission (absolutely no forward gears). I have someone willing to sell me a 4L60E transmission out of a 2000 Suburban 4x4. Only difference is that it was bolted to a 5.3l instead of my 4.3l both vehicles are 4x4, but what would be involved in swapping my transfer case info that transmission? Do the transfer cases even need to be swapped? and lastly, are the bell housing or flywheel bolts different for the 5.3 compared to the 4.3? essentially what I’m asking is what (if anything) I would need to change to make that trans compatible with my 4.3 in my blazer.
Old Dec 2, 2018 | 11:14 AM
Transman304's Avatar
I’m not 100% on the bell between the 4.3 and 5.3. Just check casting numbers of bells and if diffrent use your 4.3 bell. Also use the torque converter from the 5.3 with the 5.3 transmission. Stall speed will be diffrent but really not noticeable at all. Transfer case will bolt right on the 5.3 transmission. Good luck.
kwedge243
Nov 16, 2013 08:40 AM
jmerwin17
13
Oct 23, 2012 12:37 PM
91chevywt
Aug 10, 2011 04:57 PM
cgower
Apr 27, 2010 08:33 AM
