TRANSMISSION TICKING
Old Apr 15, 2008 | 09:46 PM
bblazer123's Avatar
bblazer123 is an unknown quantity at this point
Default TRANSMISSION TICKING
I have a 96 blazer 4.3 4x4 w/auto transmission, 130,000 miles and it has a loud ticking almost a knock sound coming from it. It shifts slowly into each gear and when it warms up to operating temp it out of over drive into drive untill i let off the gas, goes back into overdrive and the after a few seconds it slips back out of overdrive. ANNOYING!! I changed to thermostat because it wouldn't let the engine and transmission get to operating temp and the problem stoped for a day, then started again the next day. The fluid level is full and pretty clean. Did a flush and filter about a year ago. The problem started about 6 months ago. Could the transmisson be overheating? The ticking concerns me... Trying to decide if I should try and fix it or sell it as is. ANY SUGGESTIONS TO WHAT COULD BE THE PROBLEM FOR THE TICKING AND THE POOR TRANSMISSION BEHAVIOR WOULD BE APPRECIATED!
THANKS!!
Old Apr 16, 2008 | 05:31 PM
bblazer123's Avatar
Default RE: TRANSMISSION TICKING
I also read a previous post about how a bad MAFS can cause the transmission to act up. A couple years ago I replaced the MAFS with one from a 98 blazer and mine is a 96. Are they the same or can this be part of the reason for my tranny problem? Anyone???
Old Apr 16, 2008 | 05:45 PM
They are the same. I can't imagine a mAF sensor causing the transmission to make a ticking noise though...
Old Apr 17, 2008 | 06:03 PM
bblazer123's Avatar
Any idea what would? Just the tranny goin bad or somethin specific?
Old Apr 18, 2008 | 07:34 PM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
park it if aint went out yet it will if i were you i would get some to tail me my local trans shop and have an skilled tech diag. it question when was the last time you service your trany ( filter change trans fluid ) i usaully do mines every other regular oil change
pmezo
27
Jun 7, 2020 04:46 AM
S10Blazer
Jan 13, 2010 02:12 AM
willtoskie
Jan 10, 2010 04:56 PM
Bob E.
Mar 31, 2006 11:39 AM
low
Jun 25, 2005 04:52 AM
