transmission to transfer case leak
Old Dec 23, 2010 | 08:32 PM
kevinph's Avatar
kevinph is on a distinguished road
Default transmission to transfer case leak
Well, I put the transfer case back in a did not get a good seal.
When there is a leak between the transmission and the transfer case is the fluid coming from the transmission or from the transfer case?
I am trying to decide if I can drive the vehicle (minimally) with this leak or if I will end up driving with the transfer case low on oil - which would be very bad.
Old Dec 23, 2010 | 10:18 PM
old skool luvr's Avatar
that fluid will be coming from the trans.
get a gasket in there, or just use some blue RTV.
Old Dec 24, 2010 | 08:08 AM
If you use RTV, make sure to get the sealing surfaces REALLY clean and free of all trans fluid and oil.
Old Dec 24, 2010 | 08:25 AM
kevinph's Avatar
The gasket leaked the first time around and then I cleaned it and used RTV. Noticed the leak last night and am not sure how bad it is yet or where it is coming from.
I put the transfer case from a 96 into a 98 - mating surfaces looked the same when I inspected. Does anyone know of any differences?
A simple job made really hard by GM because they but the bolts in from the wrong direction from a service viewpoint!
Old Jan 9, 2011 | 05:00 PM
cpher1109's Avatar
cpher1109 is on a distinguished road
I have the same leak on mine and im planning on pulling mine back out and running studs on them like my jeep transfer case has that way all i have to do is take a nut off and then it will pop off since my leaks cause my bottem bolt striped out the threads so my only solution i feel is tap and helicoil a stud in there for all 5 of them.
Old Jan 10, 2011 | 01:21 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Good idea. Make sure you round the ends or you'll probably end up with threads that are damaged and will not accept a nut.
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
five04ever
Nov 13, 2009 08:03 AM
bw1716
Aug 2, 2008 07:38 PM
MagicMan
Mar 21, 2008 12:55 AM
