transmission trouble
Old Mar 20, 2010 | 12:05 PM
mike792car's Avatar
mike792car is on a distinguished road
Default transmission trouble
i have a 99 s10 blazer
when i go from p to d the truck starts out in drive,not 1 or 2
if i shift it manually,it works fine
Old Mar 21, 2010 | 12:51 PM
Hanr3's Avatar
Um, are you sure its not starting out in 1st gear?
D= 3rd gear provided your column also shows OD, which is 4th gear.
Why do you say its starting out in 3rd gear?
Old Mar 22, 2010 | 10:33 AM
mike792car's Avatar
well im not positive but,,,,if i take off in drive,the blazer shudders and has no power,untill i reach 30mph then everything is fine i cannot feel this car shift at all,or downshift
it works fine if i start in 2 shift to 3 then drive.
Old Mar 22, 2010 | 10:45 AM
A 3rd gear only condition could be caused by a lack of power to the transmission, an electrical short, or solenoid not being grounded properly.
Go over all of your fuses making sure that they are all still intact.
Old Mar 22, 2010 | 10:48 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
Couldnt it also be a faulty torque converter kyle?
Old Mar 22, 2010 | 11:09 PM
Doesn't really sound like a faulty converter to me though. The shudder on initial take off combined with very sluggish acceleration from a stop leads me to believe that it is starting off in a higher gear. If the torque converter were bad, you should also have an engine that was rev'ing up while getting the vehicle moving.
Crawlerchris
Jan 4, 2010 06:37 PM
jman_08
Nov 12, 2008 08:47 PM
hoffy015
Nov 30, 2007 10:17 PM
pilgrim
Jan 21, 2007 07:23 PM
blazerrick
Dec 21, 2005 04:19 PM
