Trouble confirming cause of p0420
It’s always best to fully diagnose and confirm the problem and it’s cause and then confirm the repair. The cat is an expensive and time consuming job so you want to get this one right. Also, make sure that all other fuel delivery and ignition problems are addressed first so you don’t kill the new cat.
George
George
Thanks for the information guys, I have looked into this a little more and pretty much concluded my cat is done. I think I will replace the plugs and wires when I replace the cat just for preventative maintenance even though my fuel trims are looking good. Looking at new cats online I see magnaflow wants $700 for a direct fit? Does anyone recommend anything else?
George
George
I don't have any laws about those generic cats here, I have just heard they don't last very long at all. Have you experienced this too? I would like to go with a weld in cat over direct fit though if anyone could point me in the direction of a good quality one
I've heard the weld in one's don't last. Or do and still throws a code, if you don't mind the light, then go ahead... but if you don't have a law on the cats, then maybe just look into a straight pipe lol...
But then again, that just puts a bandaid on something that could go wrong down the road...
I gambled on a none oem cat, which was made to be bolt in. And I'm sure it's causing me problems now... while christine ordered from them aswell, and had to get a shop to relocate the o2 sensor hole... so obviously was a crap job place to begin with...
I have also never needed a cat and I have a Toyota approaching 300k miles. I have read comments here and elsewhere that cheaper after market cats don’t last but I have no working knowledge of this issue. I poked around a few years ago looking for some measure of capacity or rating but did not find anything. Even the warranties looked similar. As Les implied, It would be hard to separate the quality/capacity of a given cat with how well the owner took care of the root cause before installing the replacement.
South Main Auto is the best mechanic on you tube so I took a look at one of his videos. He uses a universal Walker cat to save this customer some money and he shows the part number and mentions it being California Carb compliant. Maybe that is a meaningful assurance that the cat won’t be crap. He also shows his process for fitting a universal replacement to the vehicle. If I am ever looking for a you tube video on vehicle repair I always check him first, followed by Scanner Danner.
George
George
