Trouble in reverse and in drive
Old Jun 16, 2014 | 02:30 AM
Gav-lee's Avatar
Gav-lee is on a distinguished road
Default Trouble in reverse and in drive
I have a 94 Chevy Blazer 5.7 TBI full size automatic
For some time now I've been worried and haven't done anything about it, now that I check my tranny fluid, the dipstick is dry while it's running and full while the engine is off, it doesn't seem to want to go anywhere in reverse with out giving it a good amount of throttle, and the same goes for drive. It only seems to be bad when it's at a cold start then warms up then goes away, till the other day it's been idling rough and revving high while I'm driving down the road and then seems to catch back up.
Old Jun 19, 2014 | 09:52 PM
Tranzman's Avatar
Tranzman is on a distinguished road
Always check the fluid running in park/neutral. it should be in the cross hatched area. there is a hot and cold section on the stick. hot is considered over 100 degrees F. cold is under 100. Bottom line is the trans is probably burned up from running low on fluid.
Xaldwyn
Jul 5, 2013 05:59 PM
upmaine
Jul 14, 2012 01:03 PM
bam_9_9_9
21
Apr 10, 2011 09:19 PM
Poudre09
Nov 10, 2010 08:29 PM
Nuzman
Jun 7, 2008 11:37 PM
