truck lunging forword in forward gears
Old Dec 31, 2011 | 04:14 PM
Demon's Avatar
Demon is on a distinguished road
Default truck lunging forword in forward gears
ok i have looked around the forum and have not been able to find anything for my problem. i have a 2000 s10 LS blazer i was having trans issues so i started to rebuild the original transmission. before i was able to install it my blazer started to have a lunging problem in the forward gears. at low rpm the truck would lunge forward over and over if i gave it the boot it would pull out of it but as soon as it shifted it would start all over. i did the trans swap with the fresh rebuild and it is still having the same problem. now im thinking its an engine problem i did some reading was told to check the mafs , tps and iacv cleaned the throttle body and im running out of ideas the truck accelerates at a slow pace and when it starts lunging the tac drops and the motor does not high rev. its kind of hard to enplane the problem but its like the engine is surging on its own any ideas i could use all the help i can get at this point.
Old Jan 1, 2012 | 07:41 PM
benjamin tate's Avatar
benjamin tate is on a distinguished road
i have had similar prob a couple months back at highway speed i turned out to be my transfer case trying to shift to 4by4 low by its self and another month went by same thing but that was a timing issue distributor gear worn way down
Old Jan 2, 2012 | 12:18 AM
Demon's Avatar
ok cool ill have to look in to that i dont think its a tcase issue tho the t case that was in the truck when it started is different then the tcase that's in the truck now but with the same problem. but i didn't think about timing ill check that out thx this damm thing is kicking my *** and im loosing alot of money with it not running
Old Jan 6, 2012 | 02:09 AM
Demon's Avatar
ok well i found part of the problem the damm fuel pump was low pressure so now the lunging is gone. now the truck seems to just not have any power and is very sluggish i tried to get on the freeway and the truck hit 2nd and went but when tac hit 3 gs it just held it and didn't shift to 3rd any ideas on what would make it so slow i still don't think its a trans problem it was shifting thru all gears just cruising down the road
Old Jan 29, 2012 | 10:25 PM
Demon's Avatar
problem fixed
Old Jan 29, 2012 | 11:17 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
Originally Posted by Demon
problem fixed
what was it?
curt henson
Jun 30, 2012 09:10 AM
James1965
Jan 16, 2012 11:32 AM
visonik
Nov 27, 2009 11:28 PM
Sarahsmith854
Jul 19, 2007 09:03 PM
oshkosh
Jan 27, 2007 01:22 PM
