Truck in a way "slipping" on launch
Old Mar 7, 2012 | 03:03 PM
98cherryred's Avatar
98cherryred is on a distinguished road
Default Truck in a way "slipping" on launch
So my 98 4.3 blazer seems have what i thought was a transmission problem. From the launch it would leap or not shift properly (what i thought). Then i took it to a transmission service center and they test drove it multiple times and said they just couldn't find the problem. So now they basically have told me that a transmission problem can be ruled out. They did however mention that the o2 sensor code was coming up. Any ideas on what the problem could be? Again in my best description it seems as if it is leaping or jumping around from the launch. Once you get into third or higher, their doesn't seem to be a problem.
So could it be o2 or clogged filter?
Thanks Everyone
Old Mar 7, 2012 | 09:56 PM
Jaxer's Avatar
Banned
Jaxer is on a distinguished road
I see that 59 people have read this and are probably not sure how to best help you with this mystery problem.
I would say if the check engine light is on and has an o2 lean or rich code, then that would be the first place to start. Replace it if needed. Then make sure you are on a fresh tune up. 4.3L engine have a common issue with faulty distributor caps.... Replacing the fuel filter isn't a bad idea if its been a while, most of this is normal maintenance anyway.
Somewhere to start anyway.
Old Mar 7, 2012 | 10:51 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Is this an automatic transmission? Could you describe your problem in more detail?
Old Mar 8, 2012 | 12:01 AM
247monster's Avatar
id check the cap and rotor (distiputer) mine was doin the same thing but only when it would rain here it was getting water in it and wasnt getting a constant spark. it would dog and not wanna run worth sh*t. maybe its the same thing?? lol
bobby099
Dec 22, 2018 09:41 PM
ChevyMane808
Lowering Tech
Jun 29, 2013 02:04 AM
old skool luvr
Feb 8, 2010 09:35 PM
midnightmekanik
Oct 8, 2009 08:32 PM
Mar 22, 2006 02:21 AM
